62 Pontic turn signal switch wiring
I have a 62 Gran Prix recently purchased that came with an aftermarket turn signal assembly. I have been able to obtain the correct turn signal switch ( which has 6 male connectors in 3 rows with 1, 2, and 3 male connectors per row. I have been unable to find the wiring harness that would plug into the switch so am using female connectors to the switch. My question is what sequence the various wires attach to the switch.
Any help would be appreciated. Bill |
That GM switch; the place where it plugs-in to the dash harness does it remind you of a pyramid?
1 wire at the top and 2 in-between and 3 wires at the bottom. |
Turn signal switch wire plug-in
3 Attachment(s)
The wires to that switch (plug) will be color coded. Here is an original GM dash plug-in with a switch.
(For 1962 I think this is the style TS switch that you have.) Top of the pyramid = white. 2nd row= Left: pink, right: purple. 3rd row= Left: light blue, center: yellow and right: dark blue. |
Thank you that helps a lot. I do have the pyramid shape
| All times are GMT -4. The time now is 05:18 PM. |
