69 Bezel replacement
The back studs broke off to my 69 wiper switch dash bezel. Does anyone know if the replacement plastic chromed bezels sold by the vendors have the studs molded in? I can't tell from the photos as they only show the front.
wiper switch; plastic dash panel
3 Attachment(s)
On the backside of that plastic dash trim on the lower left (dash) you should see a pair of molded in "posts."
When you first install that panel you use what look like speed nuts that form threads onto those 2 posts for mounting your wiper-washer switch. Please note there is a very thin metal ground strap behind the dash which overlays/lines up with at least one of those posts. |
| All times are GMT -4. The time now is 02:26 AM. |
