-   -   Holley Street Dominator versions (https://forums.maxperformanceinc.com/forums/showthread.php?t=882155)
besserspat 09-13-2025 01:02 PM
5 Attachment(s)
I have a Holley SD going on one of my engines because my 71 HO intake barely made it out of Dave's SD performance shop fire a few years ago when getting a full port job.
I picked up two more Holley SDs yesterday from a very nice gentleman, I thought is would be interesting to post pics here since they are the two different versions I know of the SD.
My memory is blurry but wasnt one made to line up with the shaker hood or something? The carb pad position seems a little off and one is obviously.more open ( less casting) .
Can someone shed aome light on this . Just curious.
Peter
PAUL K 09-13-2025 02:04 PM
Nice! The one that's not cut out around the EGR boss is the first design. I always thought they changed the casting a bit to save on material. I never noticed any other differences. The first design definitely weighs a good amount more than the second.
form74 09-13-2025 02:27 PM
Looks like the one I got 2nd generation one got it with the last 400 motor I bought
Held for Ransom 09-13-2025 05:00 PM
There are three versions that I know of. I'll look after the show to see if I have pictures of them.
PAUL K 09-13-2025 08:26 PM
I perfer the later version like yours
Held for Ransom 09-13-2025 09:55 PM
3 Attachment(s)
First one has more aluminum and
FIRING ORDER
18436572 in front.
Second one had
FIRING
ORDER
18436572 in back.
Third one had
FIRE ORDER
18436572 in back.
Skip Fix 09-14-2025 10:12 AM
Those manifolds are crying for a bead blasting to look pretty again:)
I'll have to go in the attic and look at mine. Never been on an engine, got it form Speedway years ago!
They also have the W casting mark from Winters foundry like most of the factory GM aluminum manifolds.
besserspat 09-14-2025 11:10 AM
FIRING ORDER
18436572 in front.
Second one had
FIRING
ORDER
18436572 in back.
Third one had
FIRE ORDER
18436572 in back.
Isn"t the second and third the same?
TXSTARFIRE 09-14-2025 06:17 PM
FIRING ORDER VS FIRE ORDER
KEN CROCIE 09-15-2025 02:12 AM
Edelbrock Buick Performer Carb pad is set. about 1" to the rear vs B4B.
form74 09-15-2025 09:21 AM
FIRING ORDER
18436572 in front.
Second one had
FIRING
ORDER
18436572 in back.
Third one had
FIRE ORDER
18436572 in back.
Got the third version
