55 Fiberglass front end
4 Attachment(s)
I had a fellow racer make these up for me, they will be put together for a 1 piece front end. Here is the 1st initial mock up. Look to take some decent weight off the gasser, the metal i took off was roughly 200 lbs, , I don't run the full lower bumper.
Another local guy will be making the front bumper ends and grill. More of the front end is available upon request. Roughly 1500 plus shipping from TN. Hood and fenders |
That looks great! Any idea on the weight difference?
im guessing ill add back in at least 50-75 lbs going back in from the 200 i took off.
Front end is one piece now, still need to build an inner frame to tilt, will slide forward a bit as well .
4 Attachment(s)
Back together enough to make it flip, still have some bracing to do. also did some work to upgrade to a 525 box. and cleaned up firewall for a fresh coat of paint
| All times are GMT -4. The time now is 07:31 AM. |
