-   -   68 Le Lemans 350 deep to 65 389 (https://forums.maxperformanceinc.com/forums/showthread.php?t=882550)
po65to 10-10-2025 04:45 PM
I have a 68 Le Mans that I may do a swap from the 350 to a 65 389 GTO tri power with 64 heads and tri power. Le Mans has power steering and power brakes. The motor mounts should be the same, but not sure about the bolt pattern and brackets for the alternator and power steering. Has anyone done this swap? I do not have any brackets from the 389. The water pump and timing cover should be the same through 68, correct?
