-   77-81 Firebird & Trans Am TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=441)
-   -   wiper motor pump blues (https://forums.maxperformanceinc.com/forums/showthread.php?t=882673)
steve 10-19-2025 02:04 PM
I replaced the motor and lines as well as the reservoir and I get no flow even though the pump is working. is there some sort of trick to prime it or other secret to getting it going ?
Rachelsdad 10-19-2025 06:10 PM
Did you check the bellows? Be sure that you are, in fact, sucking when the piston is moving.
In my experience 3, 4, 5 cycles should get you something unless there is a blockage at the jet, a bad supply line, or a bellows not sealing tightly against the wall and not producing any suction.
Best advice OTTOMH.
Warren Seale 10-21-2025 11:25 AM
It helped when I took a mouth full of water and pushed the water into the pump through the suction line.
burd 10-21-2025 04:35 PM
I haven had fluid in mine in 40 years. Who know if it even works. You actually use the pump?
steve 10-22-2025 06:12 PM
I would if it worked. Would be nice to be able to wash the windshield occasionally when needed
burd 10-23-2025 10:30 AM
Since I posted, I removed my pump ant tested it, I forgot I put a new one in like 25 years ago, I’d bench test the one you have. I picked up 5 pumps years ago for the stash. Prob won’t need any, Get a 12v supply, bench test yours.
