Dual or single carb intake?
I am building a stroker 462 with aluminum heads for a gasser I am building for street strip use. I was wondering what intakes you guys use? Should I go with a dual carb or single carb setup? What works better?
Both seam to be about the same in my world. Others might chime in and give there results too. The two-four motor was a 440 and the dominater motor was a 462. I gota say the two 4 motor is impressive. GT |
Gasser? Run a bathtub intake, it’ll look awesome!
OFFYL Dual QUAL (dual Spreadbore for me) seemed quite responsive. And the low height with center-divider design is not shabby.
Way lighter and lower than a Wenzler Dual Quad. |
There was a recent run of Bathtub intakes that even take late model heads!
Gasser has to have dual quads at least. Maybe a Warrior TR. |
What is this going in? Post up a pic of your car! |
3 Attachment(s)
Large cap HEIs wont fit most dual quads and tripower intakes.Tom
Stock size pontiac dizzy works fine.Tom
462 11:5:1 eddy heads solid roller victor and 1050 dominator. (428) 440 eddy heads wenzler TR two 750 carbs 10:65:1 Allum rods Both motors make close to 650 hp and are pump gas motors, see a lot of street driving and drag-n-drive fun. GT |
Your car will be cool when ready to run! Looks great. Stock HEI is going to be a big PIA to run with any 2X4 intake on a Pontiac IMO. I would recommend running a stock Pontiac Points dist. or an old transistor ignition dist. to trigger an MSD box. Or a small bowl aftermarket distributor. Several brands available. If you can swing it, the Bathtub intake would look absolutely awesome in that car! I have run the old warrior intakes, the Wensler Gutsram, and the Offy 2X4 intakes. They can all be tuned to work fine in a gasser style car. A bathtub wins the best of show award. An Offy 5149 would be the least expensive by far. Good luck with it.
I want to think I have an HEI in the motor I have my Warrior TR on
KRE's intake with 2 Pro Systems Holleys
Should I do vacuum or mechanical secondary carbs? Street strip car but will drive It to shows when I can but would like to race it when I can too
| All times are GMT -4. The time now is 08:31 PM. |
