-   Tri-Power Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=569)
-   -   ID this carb (https://forums.maxperformanceinc.com/forums/showthread.php?t=884079)
Terry M. Hunt 02-02-2026 05:30 PM
ID this carb
5 Attachment(s)
Bought a 66 Tri power intake and carbs many years ago. Now taking a shot at figuring out exactly what I wound up with. Photos below show the center carb that was on the intake. Only two numbers I can find on it are 7037688 on the bowl and 31892 cast into the bottom of the base plate. I have owned Tri power cars since 1977, so I’m somewhat familiar with the setups, but I’m no expert. Much of this carb looks familiar, but the base plate seems weird. I realize it could be a Frankenstein version somebody cobbled together. Can anybody offer any insight as to what this thing is?
Terry M. Hunt 02-02-2026 05:47 PM
ID this carb
Edit: discovered more numbers stamped into choke side of the bowl as follows:
7029104
2 CB91
Kenth 02-03-2026 07:51 AM
Bowl 7029104 is 1969 Chevy 327, air horn has cast # inside, idle vent cover is a Chevy thing.
Throttle plate looks legit, wrong style idle needles though.
unruhjonny 02-03-2026 03:58 PM
I decided to look this one up in the 1969 Rochester book;
Curiously in the index, this application number isn't listed, but it is shown on the 327-2bbl page shared with the following application numbers;
7029127 (manual trans/standard)
7029129 (manual trans/air cond)
7029102 (automatic trans/standard)
7029104 (automatic trans/air cond)
Kenth 02-04-2026 04:00 PM
2 Attachment(s)
7029104 is indexed in all mine 60´s, 70´s and 80´s #9 Delco manuals.
Terry M. Hunt 02-04-2026 04:40 PM
ID this carb
Well I was pretty sure this was not correct for this set up, so I’ll see if I can send it down the road to some Chevy guy. Thanks for helping me figure out the original application on this
Joe 02-04-2026 10:27 PM
Would be interested in the carb if you're going to send it down the road. Let me know. Thanks Joe
Kenth 02-05-2026 08:12 AM
With Pontiac throttle plate and (Pontiac?) airhorn it´s not a Chevy carb either, more like a "Frankencarb."
unruhjonny 02-05-2026 05:23 PM
/\ and these days, most are!
Terry M. Hunt 02-06-2026 05:01 PM
ID this carb
Joe, you have a PM
Joe 02-07-2026 06:44 AM
Terry, PM returned last night. Thank you Joe
