-   64-65 GTO Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=429)
-   -   76X9 block (https://forums.maxperformanceinc.com/forums/showthread.php?t=884478)
4dblnkldude 03-03-2026 10:20 PM
76X9 block
I am currently on the hunt for a 64 76x9 block. I'm sure there are some experts on here. The manifest is stamped May 12, 1964 and in some documentation I have found says it was built second week of May. The production date in the upper left hand corner says 05 28. I'm having trouble making light of this. What would the actual production date be? What date code should the block be? It has a 65 76x block in it now. I have the original rear that's going back in next year and wanted to make the car period correct. Thank you for any help!
tempest1964 03-04-2026 10:15 AM
Did you check frankspontiacparts.com ? I see they have one listed at .010” over:
https://www.frankspontiacparts.com/e...iacengines.htm
Good luck
1_Wild_Cat 03-04-2026 10:31 AM
Didn’t the factory go to the two letter code instead of the alpha-numeric in 65? So any 76X would be 64 (or earlier if it was a code used before).
alex s 03-04-2026 11:43 AM
No such codes used in 1965
tempest1964 03-05-2026 09:52 AM
My mistake. The 1964 block at Franks’s was a 78X block, not a 76x.
4dblnkldude 03-05-2026 10:35 PM
I did check Franks.
GtoFM 03-06-2026 12:15 AM
Do you have the PHS? The manifest lists the engine in boxes 75 & 76. If you don't have PHS documentation, get it. What is the date stamp in the upper left of the cowl data plate? S/b 05B, May 2nd week.
4dblnkldude 03-09-2026 09:13 PM
Yes it is 05B. So would I be looking for a date code of late March/early April or so?
johnta1 03-09-2026 09:26 PM
What plant is the car from?
:confused:
tempeonempty 03-09-2026 10:07 PM
No such thing as a 65 76x block. The only plausible explanation (I can think) might be it is a warranty replacement in 65 and the tech stamped 76x to replicate the original block. If that is the case, I'd probably leave it in the car and call it next best thing to the original.
Some plants put the EUN on the manifest. Is there any chance the block is actually a 64 76x, it could be original? 05B would indicate the body was built in the fisher body plant second week of May. Production Date I think you are referring to Invoice Date which is the date the car was invoiced to the dealer when it was completed and this in most circumstances happened within 1 to 2 days the (completed) car actually rolled off the assembly line. I'd presume you want a date block 2-3 weeks prior to the invoice date but I'm not 100% versed in that time frame on 64s. Also depended on what plant car was built. You'd want to find a similar examples of original cars to reference if you're trying to be as accurate as possible.
76x blocks are rather difficult to find. Good luck in your search!
GtoFM 03-12-2026 11:15 PM
OK, the car was built the 2nd wk of May. What does the manifest list in boxes 75 &76? What are the numbers cast in the block near distributor? S/b 977.... & date code like C164. What is stamped on the block on the right (passenger) front side just below the head? Pics of all of this would be most helpful!
4dblnkldude 03-15-2026 07:52 PM
I will get pics on tomorrow!
4dblnkldude 03-15-2026 07:56 PM
Got a pic on my phone....in box 75 it says 7 and box 76 says 6.
johnta1 03-15-2026 08:19 PM
That would be the engine code 76 for 389 Manual tripower engine
What's the code in Box 77?
4dblnkldude 03-16-2026 09:21 PM
The number 9. The block code on the front is 76XW with the number 358808 under it. Date code looks like K185. I cant get good pics the car is on the lift. Bock number back there is 977878 think 9 at the end.
4dblnkldude 03-16-2026 09:36 PM
See pics…
Ugghh
johnta1 03-17-2026 07:21 AM
Very interesting engine!
I'd say it was a replacement short block for a 64 GTO? car.
I think that a dealer would/should stamp the replacement engine with the original EUN/code?
That engine is actually a Nov 1965 block which they were probably making engines for 1966 model year.
Looks like that eun would be around a 03D car in 1964.
johnta1 03-17-2026 07:56 AM
Your car a Fremont or Pontiac built GTO?
On the BHC (if Fremont/Pontiac), to the left of the VIN is the engine code and a set of numbers.
What are those numbers?
Or post the BHC if you want.
:confused:
4dblnkldude 03-17-2026 09:49 PM
Here it is.
