Reverb switch
2 Attachment(s)
If you ordered Reverb on 65-66 fullsize that also has power antenna and rear window defroster, would the Reverb dash switch take the place of the Front\Rear Speaker switch? In other words, would it still have only three switches, or possibly all four?
That is correct, the reverb switch replaces the speaker switch. It has F Reverb R on the switch which means you can select front speaker (no reverb), reverb (which gives you both speakers on reverb) or rear speaker (again, no reverb).
| All times are GMT -4. The time now is 04:03 PM. |
