-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   Moderately Priced Flexible and Locking Turbo 400 Dip Stick Tube (https://forums.maxperformanceinc.com/forums/showthread.php?t=885353)
CraigG. 05-09-2026 09:43 PM
Hey Guys,
Where to find a Moderately Priced Flexible and Locking Turbo 400 Dip Stick Tube?
Thanks Again.
Craig
Mike Davis 05-10-2026 07:48 AM
If you have a dipstick....
This is what I used
https://www.summitracing.com/parts/a...gaAjP0EALw_wcB
The only flexible I am familiar with is the Lokar at $200+
HWYSTR455 05-10-2026 09:04 AM
Interestingly enough, I've found that many TH400 dip stick TUBES don't fit, even ones that are listed for the application. I at one time had a graveyard of tubes/sticks because of this.
If you need the tube and stick, this is the one that I've used on both TH400 & 4L80e, in both 68-72 A-bodies and 2nd gen F-bodies:
https://www.summitracing.com/parts/tci-743803
I believe I have used the ATI ones as well, but the TCi one was the first I found in my notes.
CraigG. 05-10-2026 10:06 AM
Hey Guys,
Thanks and I should have said full length 72 gto and flexible.
Craig
HWYSTR455 05-11-2026 09:04 AM
The only ones I'm familiar with are the Lokar and Autoloc ones, and IMO, the Lokar end that you trim is kind of sloppy.
It works, and if you're careful, you can make a good end, and will work fine.
The Autoloc ones come in different lengths, so you can get one close enough where you don't have to cut them.
Last I looked, the Lokar one only comes in 1 length.
B&M used to make one, but I've never used them, so can't really comment. Suspect others make them, there too, have only used the Lokar and Autoloc ones.
Dragncar 05-11-2026 04:27 PM
ATI makes one for 20 bucks. But no dipstick attached.
I keep one around if tech asks for it.
But I keep my stock one on the car with a little zip tie looping around the bracket that bolts to the rear of the head.
They let me get away with it but keep the locking one in toolbox just in case.
