Best Underhood Semi-gloss Black Paint??
I will be repainting my '71's inner fenders and radiator support soon. Haven't had to do this semi-gloss shade of black in several years now, and the products I used to use no longer exist. What have you guys found that is a good match for that underhood semi-gloss black?
If youre using a spray can... krylon satin is an excellent sheen & good quality paint, have used it on many parts under the hood etc, goes on smooth, dries fast & holds up to engine heat or debris from under the car.
Or if using spray gun, lots of options for brands, just ask for a color chart to show the sheen you want. |
X2 Krylon Satin
X3 Krylon satin, I’ve also used Rustoleum satin and like that as well.
But if cure time doesnt matter then its a good option, just do a test spot to see if you like the sheen. Another option but more expensive is Eastwood paints, I tried some of their chassis black I think its called, good paint but for a fraction of the price and available locally, the Krylon satin black looks just as good IMO. |
DP90LF
Spray gun DP90LF is the best and very resistant to chemicals since it is 2K. Pefect color match in my opinion.
Spray can is Tuff Coat I think it's from O reilly's in Lacquer. Not very resilient but looks good. |
I prefer Duplicolor when it comes to rattle cans. It seems to lay down the best..
DP90 would be my first choice. Very durable. Reduced 20-30% gives a nice semi gloss sheen. Yes it is expensive. One of the most, you get what you pay for products, I’ve ever used.
Chalk
Please expound on this. Maybe I can try a new one that works. They all seem to go chalky black over time Except for the PPG. You get what you pay for. All my high dollar resto's get PPG everything until I find something better. LF works just as good as the leaded product. Still have both and use the leaded on certain items. 2K is an acronym for 2 part. I think we all know it's an epoxy primer. |
Under hood black on 2nd Gens is NOT all the same gloss level.
Inner fenders & core support had a higher degree of gloss to them than the face of the cowl, and for that matter DP90. So did numerous supplemental parts like the '73, & '74-75 fender bars. |
Radiator supports were dipped, but not positive about inner skirts whether they were dipped or sprayed. I love to pop a hood on a restored GM car and see different gloss levels on different items. "My kind 'O guy!" |
Used to use DP90 and liked the end results. Can't find it or L.F. anywhere anymore. For poof cans used Eastwoods Underhood Black. Very black and close semi-gloss finish. But mars SUPER easy. Even just doing normal dust removal cleaning leaves scratches. Krylon Satin Black (or Semi-Gloss) to my eyes is not very black. More charcoal looking and not enough gloss.
Have recently tried Rustoleum 2X Ultra-Cover Semi-gloss. Very black and decent semi gloss. But takes forever to cure. Small parts can be oven cured to speed up the process but big pieces are a pain to handle for almost 24 hours. Thanks for all the input. |
| All times are GMT -4. The time now is 11:44 PM. |
