-   -   What air horn can I use for a 7042263 Quadrajet? (https://forums.maxperformanceinc.com/forums/showthread.php?t=885966)
67Lemons 06-21-2026 08:01 PM
One of the accelerator pump ears on my ‘72 Quadrajet is cracked and I want to replace the air horn, since I can’t find the exact carb as a core, what other numbers can I use?
Kenth 06-22-2026 04:05 AM
You may consider this:
https://www.carburetion.com/Products...px?part=R24-55
or:
https://quadrajetpower.com/accelerat...ng-repair-pin/
HTH
67Lemons 06-22-2026 07:09 AM
Originally Posted by Kenth (Post 6621110)
I have one and installed it but not confident in it as a long term solution, I’d much rather a replacement air horn.
carbking 06-22-2026 07:46 AM
The airhorn used on the 7042263 carburetor is unique to that application.
If it were mine, I would simply repair the original. It really is not difficult, I have posted the method on this forum in the past.
Jon
chiphead 06-26-2026 02:31 PM
I've got a desirable core that has this ear broken. Its been in a box of carbs for years, I figured it was wasted. Thanks for this!
Half-Inch Stud 06-27-2026 06:57 AM
Repair is realistic. Did that and it held for, well probably still holding.
