-   61-77 GTO LeMans & Tempests FOR SALE (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=460)
-   -   SikGoat 69 GTO For Sale (https://forums.maxperformanceinc.com/forums/showthread.php?t=886038)
wreckmastr 06-26-2026 06:58 PM
CAR WILL BE AT NORWALK IF YOU WANT TO INSPECT IT IN PERSON
SikGoat 1969 GTO (Real GTO) Race car / Street car
This is car is one of the cleaner 69 GTO’s out there. It’s been on the cover of Car Craft magazine and the banner car for the 2 PRI shows so you may have seen it around. It is street legal all lights work, all steel body (except hood), All factory glass windows that still work, Full original dash, door panels headliner and carpet interior. Stock GM floors to the main hoop. 25.5 cert round tube chassis from the firewall back. Ladder bar / Coil over rear suspension. TRZ front control arms and Billet TRZ steering arms, Flaming river rack & pinion steering.
505c.i. Pontiac motor, All Pontiac IAII solid cast aluminum block, Bryant Billet crank
GRP 6500 series aluminum rods w/ 1.094 tool steel wrist pins, Diamond coated pistons
55mm LSM cam, Jesel .904 lifters, Manton 7/16” tool steel pushrods.
Visner billet heads water jacketed with top fuel hoops, Titanium intake valves / Inconel exhaust valves. Intake and exhaust ports are O-ringed so are the valve covers.
Visner Steel exhaust / Visner aluminum intake shaft rockers, Pac valve springs
Visner billet intake, Visner billet 120mm throttle body, Visner billet valley pan,
Visner large bore fuel rails with Billet Atomizer 225lb injectors, All Goodrich crimped hose’s
Visner billet valve covers (2 sets), BOP belt drive w/ MSD front mount dist., ATI Balancer
Billet front motor plate, Billet Daily external belt driven oil pump, Aeromotive 11gpm belt driven fuel pump.
ProCharger F-3 136 w/ Supercharger store gear drive and all billet brackets.
Rossler 3spd TH400 with Ultra bell 1-3/16” 27 spline input shaft and Rossler external dump valve.
Billet aluminum and steel bolt together Neil Chance 10” torque converter with an extra stator.
Carbon Fiber PST driveshaft, FAB-9” rear housing with antiroll bar. Precision Products air shifter.
9” Moser aluminum center with Moser 40 spline spool and Moser 40 spline axles. Strange brakes front and rear.
Santhuff coil over shocks front and rear. Shearer Fabrications 4000 series water intercooler.
Mickey Thompson Pro ET5 front wheels, Sanders double bead lock 15x15 rear and M/T 315 drag radials.
FuelTech FT550 ECU the following sensors:
Oil pressure Torque converter pressure Laser ride height sensor (Wheelie control) Davis 32 tooth drive shaft sensor
Fuel pressure Air temp. G-meter 2 – O2 sensors
Water temp. Rear shock travel sensor Map Sensor TPS
Racepak V300SD (with tons of sensors) Racepak Smartwire system, Voltphreaks 16v lithium battery 6lbs,
Too much to list. I have tons of photos and video's or you can search YouTube for "SikGoat"
At a weight of 3600lbs the car has been a best ET of:
60’ 1.13
330’ 3.00
1/8th 4.53 @ 161.2
1/4 6.98 @ 199.9
Comes with tune ups and lots of spare parts. Plenty of Videos on YouTube. Just search “SikGoat”
$118kOBO
For more information and details call PM or call me
443-223-7897
https://scontent-iad3-1.xx.fbcdn.net...Ww&oe=6A44BEDF
https://scontent-iad6-1.xx.fbcdn.net...rw&oe=6A44DF15
https://scontent-iad3-1.xx.fbcdn.net...jw&oe=6A44DF5F
https://scontent-iad3-1.xx.fbcdn.net...dg&oe=6A44D10B
https://scontent-iad3-1.xx.fbcdn.net...Tg&oe=6A44CB20
wreckmastr 07-03-2026 09:48 AM
Can be bought as a roller as well.
