-   74-76 Firebird & TA TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=440)
-   -   Weight of a 15” Honeycomb wheel? (https://forums.maxperformanceinc.com/forums/showthread.php?t=886065)
1911a1 06-28-2026 03:28 PM
I was curious if anyone happens to know or has weighed a factory 15” honeycomb wheel?
One of mine is off now but of course it has a tire on it. It seems mighty heavy to me.
Wondering the difference in weight between a factory and aftermarket 17” cast aluminum wheel.
P.S. don’t have the scratch for the billet honeycombs I found on line.
Nobuddy 06-28-2026 04:12 PM
I have an original 15x8 setting here to get tires tomorrow. 19.2lbs.
So many and much better tires available for the 17 but it might not be lighter.
'ol Pinion head 06-29-2026 01:59 PM
The 15x7 Honeycombs w factory trim ring & center cap weigh right around 30 lbs. Will post back w an exact to the ounce weight.
The only thing heavier that I've ever pulled and shipped in a factory GM performance 15x7 steel wheel are the '86-87 Grand National wheels.
Chrome with black accents, they come in right under 32 lbs.
For comparison, late '60's, early '70's 14x6 GM A-body steel wheels typically come in around 18-19 lbs.
Have a list at home of exact weights, numerous sizes, some weights also with mounted G70-14's. F60-15's, and G60-15s.
Nobuddy 06-29-2026 05:36 PM
Sorry - This registered as snowflake not honeycomb which I suppose is obvious from the 15x8. So lease ignore post #.2
Barry
