-   -   Which intake gasket (https://forums.maxperformanceinc.com/forums/showthread.php?t=886337)
Terry M. Hunt 07-19-2026 07:10 PM
Which intake gasket
2 Attachment(s)
I may have posted this question before but can’t find it using search function. I’ll be sure to record the answer this time. Rebuilding engine in my 66 GTO using Fel Pro gasket set 2601025. It contains two different intake gaskets(see photos attached) . Which is correct A or B? A is stamped 90205 and R3. B is stamped 9980 and R 4. Also, does the printed side of gasket face the head or the intake or does it even matter?
johnta1 07-20-2026 05:57 AM
If it has the 66 heads use B.
Kenth 07-20-2026 08:43 AM
A is for 1972 and later intakes with any year heads.
B is for 1971 and earlier intakes and heads.
Terry M. Hunt 07-20-2026 04:22 PM
Which intake gasket
Okay B it is. Does it matter which side of gasket faces the intake?
Kenth 07-21-2026 04:15 AM
They will fit only one way.
HTH
unruhjonny 07-21-2026 12:44 PM
when in doubt;
Use a gasket that matches your heads.
Kenth 07-21-2026 04:13 PM
Again, 1972 and later intake gaskets will fit any heads IF a 1972 and later intake is used.
A 1971 or earlier intake WILL leak exhaust on passenger side on 1972 or later heads unless special measures are taken to cover/eliminate the blind hole above the crossover channel on the passenger side.
