-   Tri-Power Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=569)
-   -   end carb venturi clusters (https://forums.maxperformanceinc.com/forums/showthread.php?t=886344)
Joe 07-20-2026 01:02 PM
on the left is an OEM piece. One on the right I pulled the idle tubes out to use on an end carb. Do I need to fill the holes with some sort of epoxy or use as is. thanks Joe
Kenth 07-20-2026 02:06 PM
Since there are no idle channels in end carb bowls and plates you can leave the idle tube holes as is.
However youŽll need to plug the upper idle air bleeds and open the main well air bleeds and accelerator jets to end carb specs.
Joe 07-21-2026 08:52 AM
Thanks once again for your help. for clarification... when you state upper idle air bleeds are those called " primary idle air bleeds " ? If II have to plug them I should be able to syringe some liquid epoxy down the hole where I pulled the idle tubes out correct?
also, what do you mean by accelerator jets?
Much appreciated.
thanks again,
Joe
