-   -   70 Power Steering struggles (https://forums.maxperformanceinc.com/forums/showthread.php?t=886373)
F Body Freak 07-21-2026 04:53 PM
As some of you might have seen, I recently got my Formula back up & running. One of the things that got rebuilt this winter was the power steering pump. It wasnt having any issues, other than it leaked. Everything looked fine inside, & from what I recall, the youtube video of the rebuild was pretty straight forward. Took it apart & replaced all the seals & o rings & re assembled.
It has correct amount of fluid, belt seems to be spinning fine. No weird noises or whining, but I got no power steering. From what I researched online, maybe its air locked? I jacked the car up, turned the wheel from lock to lock 20 times. Checked fluid. Added a little, fired the car up & did it 20 more times. Didnt see any foaming or bubbles in the fluid. It did puke some fluid out tho. I think this was from having to much fluid? Not sure tho. Checked fluid again, after some came out & it was still at the correct level. Did the 20 turn thing again. This time I watched as momma turned the wheel. No leaks, no weird noises, no loss in fluid level. Was hopeful it fixed itself. It sure turned easy while on jack stands. 🤓
But when I pulled it back in the pole barn, still no power steering.
Just wondering if theres anything else I can try before I pull the pump off?
Singleton 07-22-2026 11:57 AM
Is it possible that you have this part, (red arrow ), upside down? Or possibly have the small vanes in backward. One side of vanes are more rounded than the other.
F Body Freak 07-22-2026 12:10 PM
Anything is possible, unfortunately 🫤
Probably try the lock to lock turn thing again, & another short drive. 🤷 Then it's gonna have to come apart & see if we can figure out what's the matter.
BB70 07-22-2026 04:27 PM
Rev it up a couple times, I had that happen before.
Tellyshavilli 07-22-2026 05:34 PM
Went through this last year with my 70 Trans Am
OG68 07-22-2026 07:56 PM
Make sure the pressure relief valve isn't stuck. Just the finest spec of dirt or dog hair (in my case) will jam it in the cylinder causing a no pressure situation.
