[QUOTE=Greg Reid;3609711...unplug the wire. Should be full. Ground the wire...Should be empty. You're taking the sending unit out of the circuit to test the gauge.[/QUOTE]
Its gotta be the gauge,
If I unplug the wire it shows full...if I ground it (unplugged) it stays full..only plugged in and grounded does it go empty.
I found one on ebay..should get it this week.
Thanks Greg!
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
