98 bonneville problem
any help greatly appreciated.98 bonneville with good blower motor(I ran 12 volts to it)can't get any speeds from using fan switch.Only getting 1.8 volts thru harness when turned on.30amp AC fuse is good.Could relay be bad?How do you check a relay?Does anyone know exactly which relay it is?thanks in advance.
