Originally Posted by Mister Pontiac
Any of you guys swapped out the idiot lights for Rally Gauges into your '72's? If so, was it a simple swap, or is there some rewiring to consider? I don't mind either way, just looking for the voice of experience here from you guys...
Are you a seat belt warning light car or not? If so, supposedly you can just drop it right in (per conversations I've read here). If not, then you have to swap 1 or 2 wires I believe. Factory wiring diagram shows which one, I can't remember off the top of my head now.
Also remove the green wire from IGN3 terminal (this grounds the temp bulb when cranking the engine, which is not something you want to do on the gauge).
