11-18-2013, 01:22 PM
For those not tracking this on another forum, I didn't get to fire it up due to the fuel rails not performing to expectation. Below are posts of the last two weekends.
It was a long day that ended with out start up yet. During non-running systems testing (nifty megasquirt feature) I found I had the wiring to two ignition coils swapped and two fuel injectors not firing. Fairly quickly tracked down the crossed wires on the ignition, and I coincidentally had two spare injectors (all the injectors are used ones off my Skylarks 455 V8 from when I up-sized the injectors on it) BUT one of the spares wasn't firing either. That could of been a game stopper, so I got some carb cleaner and sprayed the heck out of the injectors and managed to actually get all three non-firing injectors working. I guess they got gummed up from left over fuel and sitting. Then was on to crank and cam sensor testing without fuel or spark. Engine cranks fast and builds some oil pressure during cranking. I had a good and clean crank signal from the start but wasn't getting a cam signal. I spent an hour troubleshooting it, had an LED test light I made showing the cam sensor was sending a signal but the megasquirt wasn't picking it up. Turned out I had to remove the jumper in the megasquirt that is supposed to be a pull-up circuit and install an external pull-up circuit. I don't know why, but it worked. It was the only picture I took today, the screen capture of the cam and crank single, lol. Once I had that I set up the fuel system to pressure check it and set the regulator pressure. This was a point of concern, and it turned out to be valid. At least three of the injectors are leaking at the rail :*( so no start up today. Tomorrow I plan on removing the whole rail set up, possibly run a scotch brite pad on a drill bit into each hole to polish it up, install new o-rings on the injectors and try again.
The green line is the cam signal and the blue line is the crank signal. The missing tooth is easily visible on the crank signal and the cam signal is about 30* before the missing tooth that signifies TDC compression stroke on cylinder 1.
I was set back yesterday pretty substantially when my fuel rail system did not work out. I cleaned up the holes, replaced the o-rings, etc to no avail. So I am going to a common rail but ran into the exact problem that caused me to look at "alternative" fuel rail configurations, namely I either have interference from the thermostat housing or with the throttle body. I simply cannot get a straight line to fit.
I got word the guy giving me a remote mount automotive electric water pump has put it in the mail on Friday so I yanked the thermostat housing off the engine, removed the intake, chiseled out the injector bungs, re-installed the intake, hung the fuel rail in place with injectors installed and bungs hanging from the injectors into the intake, and put a fresh coat of JB quik-weld on it. I now have a second coat of JB quik weld on it to make sure it seals and holds and will clean up and re-paint the intake this week.
I ordered up some 1/4" aluminum plating and will make a water outlet block off plate and a water pump hole plate and bolt a water outlet to the pump plate. I've already knocked out the two freeze plugs and installed the ones I welded nipples onto. Going all out on the external water pump now.
My friend Bill rules all.
This arrived today. It's a 21gpm unit, which trumps the 17gpm (at what rpm?) unit on the OHC engine. I've picked up a T from the hardware store too, so I just have to get some hoses to plumb this in. He sent it with a controller as well, which will control the pump speed based on temperature. No thermostat needed, if its cold it'll be off, if it's hot it'll run full speed. GAME ON!!
https://fbcdn-sphotos-f-a.akamaihd.n...22272295_o.jpg
The highlight of today is I installed the 4.56 gears and the mini-spool into the Firebird. While the axles were out I checked and they fit nicely in my old 8.5" rear end with a true positraction and 3.42 gears. If things go south with the mini-spool and it doesn't take an axle out I can swap the rear end assembly if needed. I really want to run this engine with these gears! It'll be 3,000 rpm at 75mph with the overdrive.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
