Originally Posted by AZ64GP
I can see why the head would not come up. The bolt broke off about a 1/2" to 1" below the top of the head, so most of it is still rusted and stuck in the head/block.
Originally Posted by scld1354
Get the broken bolt red hot with a torch.
Originally Posted by 61-63
just keep getting it cherry red, let it cool down, and then try to remove the head. If the head won't come off do the red hot/cool down/try to remove again. After three or four cycles you will probably be able to get it off.
How would you guys heat a bolt cherry-red when it's recessed inside the bolt hole of the head that won't come off?
I sure don't know how I'd accomplish that task.
