Originally Posted by pfilean
I thought back in the old days it was common for the factory owners/service manuals to ask for coolant about 1 inch below top of radiator.
I would like to clarify this point after I found this thread in a search.
I’m leaking a small amount of coolant, small trail present after engine shutdown, no catch tank.
Takes about 1 pint to ‘fill’ it up, only to puke it out again...
However this ‘natural level’ that’s 1” below the rad top is just below the top of the row of the cooling tubes, so the top row is not sitting in coolant when cold.
Is that OK? I’m thinking that’s likely to cause corrosion?
Appreciate your opinion. Thanks
