Last night I went out and lowered the temp settings I had on the fans. Low on at 180/off at 175. High on at 185/off at181. Now just need some hot weather and some time to take for a test ride. Would be something if something that simple makes the difference. I'm not holding my breath. Think I had the high set to come on at 195 before and it went to 206 in the heat. So better than 10 degrees higher anyway. I'm not holding my breath. That would be a very thin thread to hold onto to expect it to operate correctly under extreme conditions.
I'm still thinking dual 12" fans in a well fitting shroud may be in the near future.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
