I'm not much for the match bot but my experience bot knows that a 1.32 ar s475 will work good on a 351w engine. If you want a lower rpm set-up you may want to go with the 1.10 ar instead it will spool up about 5-600 rpms quicker. The turbo doesn't know if its on a Ford, Chebby or a Pontiac.
