Originally Posted by Rich D
Thanks guys. I was thinking that running it a couple degrees less would be safer for the motor. I plan on racing it a little but mostly show and cruise nights. I set it down to around 30- 31 degrees. Hope to try it at a local track soon. No roll bar so can't run faster then 11.5 anyway. Thanks again
Sounds like a great build, just go to the dragstrip on street nights or days..most tracks I go to are quite easy on tech on those days. The nice thing about the dragstrip is that good or bad any issues with the car will show up.
Also I see your in Colorado..so at a higher elevation a 11.5 is a pretty good achievement.
