Originally Posted by north
Even though the two GTO switches in the photos above aren't in the same exact place the both fall into that large hole in the inner door frame. the 70 plus power locks mimic the size and shape of the 70+ power window switches (which were redesigned in a more angular shape). Therefore the 70 electric lock switch is too small to fill the much taller 69 vacuum lock switch opening.
Yes I can see that it's going through the same door location on both doors in your photos. However, if you look at post number four in this thread, Ben M posted a picture of a '69 LeMans with the vacuum locks and in that picture it appears the switch is several inches closer to the front of the door.
Attached is a picture of the small opening that I ran my switch wires through, and my switch location seems to coincide with the switch location in his photo.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
