Vacuum advance connection
Thank You 78w72,
I have a Holley 750 carb with vacuum secondaries and a Summit HEI vacuum advance distributor and since the vacuum connection is on the front of the carb at the base this is manifold vacuum because it is below the throttle valves on the carb? Also I have my vacuum modulator on the auto trans hooked up to a high point connection on the carb. Is this correct since I want all of my vacuum connections hooked up stock OEM?
Carousel72TRed
