Originally Posted by Dragncar
Nice pan. I had them put in a provision for a dipstick on pass side and a 1/8" bung with baffle just below pan rail for vacuum fitting. I should have had them put in a oil return fitting just forgot to ask. They sent me some weld in bungs if I want to do it myself. But running High Ports so I do not think I need one.
I made my own oil pump pickup for a pump I enlarged to .915 on suction side.
Did you buy the Steffs pickup ?
Are you planning on running a gasket or just use The Right Stuff and no gasket like some do ?
One thing I have done is buy I-Js teflon crank scrapper to add to it all. You can actually touch the crank with this scrapper. Kind of expensive at 230$ but if it gives me more power its worth it.
I-J told me this scrapper can add 3, maybe 4% horsepower which is a lot if you think about it. A regular steel scrapper gets you 1-2% more horsepower he said.
Aluminum block, she is going to be badd @$$.
She's been Bad$$ for about a year!!!
Johnny, is the blower going on it???
Hope you can make Great Bend. Last year was pretty ho-hum with that long oil clean up...
Shut it off
Shut it off
