Originally Posted by Stan Weiss
While 0.050" duration might be what people want to look at. You really also need to know the seat-to seat duration is to get an idea about what cylinder pressure will be. The RP which someone said has 306 / 307 degrees seat-to-seat from what I can see. I believe this is about the min.seat-to seat duration you want to be looking at. Where you place the ICL also will factor in.
Stan
The cam I mentioned above in the 571 that Paul spec'd is advertised at 318/326
https://youtu.be/XqEydRRRwqE
