Idk how thick the hylomar hi temp is but I use hylomar on al my gaskets it’s amazing because it’s non setting, it’s thin and very unnoticeable. I haven’t used it in exhaust situations because I usually use no gasket and just use copper RTV because I learned that w turbo headers was the best solution and have always stuck with it for that application.
Maybe you could copper rtv it on each side of metal and keep it from showing IDK. I have had to remove headers w a hammer before because the copper seal rtv had bonded so well to the head.
Could try this but have no experience with it the hylomar M is amazing though. Best gasket sealant I’ve ever used.
https://hylomar.com/en/exhaust-assembly-paste/
960 HP @ 11 psi, 9.70 at 146.
