If you are using a single chain with just 2 bolts for the PS find the 3/8” bolt boss on the side of the head either at the front of the head or right behind the coil.
On the DS since the intake and exhaust are off, just use one of the manifold bolt holes towards the rear of the head that allows you to balance the lift.
Avoid the power steering, alternator and AC mounts as they are all cast aluminum.
