The access hole for the remote mirror cable is centered 12 1/2" from the front edge of the door. That is on a level plane, measured 2 1/2" down from the window side of the outer window fuzzy. The access hole is 3/4" in diameter. I can take a pic showing the smaller mtg holes if you like & text it to you.
Last, the black plastic mtg pads for '71-72 Sport mirrors are different than 2nd Gen Bird which is different than 2nd Gen Camaro.
