If the blower runs at full speed with +12 directly to it, but not in the intermediate speeds, the blower resistor pack could be suspect. They can go bad. As for the switch, a can of spray electrical contact cleaner may help. Spray it down good and move it bak and forth through the different positions to rub the corrosion and dirt off the contacts inside the switch.
