I am genuinely surprices that you have an ITM shifter.
I wonder if it was swapped out, because Pontiac was still using Hurst shifters at that time.
I would guess that it should be the exact shifter that a 1973 GTO or 1973-1975(?) Lemans would get.
Maybe put it out to the proper sub-forum;
I would guess that the A-body still used a different shifter assembly than the F-body - but if they were the same, you've got it made!
1970 Formula 400
