Acceleration stumble cause?
I think i migth have too much breathers/ventilation on the engine. I think what is going on is the pcv inhales trough 1x breather and 1x fresh air line coupled too aircleaner -> valve cover. causing too much unmetered air in the intakmanifold diuting the the AFR. O2 sensor sees it fraction of a secound later and over corrects. after capping off my breather and restricting the fresh air line. til i have vaccum in the crank case have made acceleration work a lot better.
Does this sound like an reasonable cause?
Murphy's law - "Anything that can go wrong will go wrong".
-469 ,Butler 310+ Eheads, Hurricane intake portmatched by butler, Butler roller 230/236 @0.50 112 LSA, Johnson lifters, pypes 2 1/2" exhaust, 3.42 yukon duragrip lsd, holley sniper efi, hyperfuel efi tank +++
