06-25-2023, 06:34 PM
Originally Posted by Marv
...and going distributor-less let's you run sequential ignition timing for much better ignition control - this isn't needed but let's you get the tune dialled in far better than adapting to a dizzy.
The Eddy system IS sequential.
...then setting up a proper standalone ECU and piecing your control package together yourself is the way to go, IMO.
There is a much steeper learning curve here; the Pro-Flo setup is close to plug-n-play.
