You don’t need to remove the turn signal lever and even if you did it’s not difficult to do.
I’m not trying to sound rude but I don’t know what other help you want. The way I explained is the only way to get that cover off. I promise you if you manage to get the cover off without removing the upper collar you will not get it back on even assuming you don’t break it.
1977 Trans Am 400/4speed (swap)
Brian
