Do you know what the coil bind is on your springs? 1.76” IH with 1.65s might be getting a bit tight? You may want to try to would shim the seat pressure so it is balanced out with a plus 050” distance from coil bind, take the hot lash off the lift numbers. As long as you get the coil bind distance correct with the pressure numbers mentioned I would ship it.
Unless it is a different .3994 lobe than I am familiar with, the .3994” I recall are not very aggressive roller profiles, you have plenty of spring pressure for it.
