View Single Post
Old 04-18-2024, 06:33 PM
Here are a pair of 1964 slash shields. One has a factory A/C sheet metal baffle installed on the bottom, clearly both A/C and non-A/C applications used the same splash shield.
The 1964 A/C baffle has a narrow extension that wasn’t used for 1965 as you can see in the last 2 photos (‘65 baffle at the bottom). The drivers side 1964 baffle is an original, the passenger side baffle was fabricated for me by my brother, they’re not easy to come by.
Right now in the process of restoring the factory A/C on my Le Mans convertible.
ID:	632288   Click image for larger version
ID:	632289   Click image for larger version
ID:	632290   Click image for larger version
ID:	632291   Click image for larger version
