View Single Post
  #97
Old 09-04-2024, 11:25 AM
Stan Weiss's Avatar
Originally Posted by Matt1970gto View Post
Don made a couple suggestions the other day when we spoke.. Welding the head up to reduce the cross section, going to a 2.400 valve but would still have a csa around 93% & having a different cam cut by Scott Brown. I got a quote a couple months ago of close to 10k to build a new intake.. 10k for intake, 2500 headers, rework the heads , new cam & at or above a set of tigers or pro ports. Just not sure how much more I want to go down the rabbit hole.
Matt,
If I remember correctly you and your father started out with the same head casting, but had different people do the work and, his engine had a much better torque curve.
Stan
Pontiac Pump Gas List
