View Single Post
Old 08-03-2008, 09:47 PM
judgethis judgethis is offline
I have the schematics I just dont know how to move them around on a computer. So Ill try to explain. Do you have all the connectors to go with the seat track from the switch to the track motors? Power is supplied to the seat track switch at terminal F (orange wire) and ground is terminal C will be ground (black wire).
For the lumbar: supply power to terminal A on the Seat Cushion Air Control Module connector. Ground is supplied to terminal D of the module. Supply power to the F terminal of the lumbar switches.
Hope this helps.
