I read alot of great stories about those plastic headliners not fitting up. I just did a headliner in my 1978 Trans Am last week from AMES. The hardest part of the headliner is removal and installation. Once the board is out, scrape off the old foam, go over the entire board with a red scotch brite pad to make sure you have ALL the old foam off. Blow it with a blow gun then get out the 3M adhesive and go to town. Trim with a sharp razor blade. Not only did it come out perfect, the board fits the car! Also this is the way Pontiac did it and the only way that's factory correct... which sounds like that matters to a few members on here.
Redline Design
