Water pump pulley bent?
I have a two groove water pump pulley that looks to be bent or maybe the water pump shaft or mounting plate for the pulley.
If I find that it's only the pulley, would I be doing damage to the pump shaft or plate if I gave the pulley a smack or two with a piece of wood and hammer, while mounted?
If it's the pump I will replace.
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
