Originally Posted by Goatracer1
Trans cooler are in the cool part of the radiator so the temps are generally not a problem.
If the Coolant is at 220 degrees, the Transmission is at close to 220 degrees. The "cooler" is INSIde the coolant tank. While its on the return side, it IS vertical in the tank so its subject to the coolant at top of tank.
Obviously an auto trans doesnt cook "instantly" so its not of concern to many folks.
