Had my dominator sealed to the bottom of my hood using an air cleaner base and foam. Forward facing scoop. It was worth a little less than a tenth over no scoop.
I can tell you with complete confidence that your ET drops from single digits to the mid 20s when you accidentally leave the scoop plug in for a run and your sealing efforts were unexpectedly good.
oops!
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
