Swapping rears is not that hard, its even easier if ya weld up a support bracket that attaches to your jack to hold\move it. Disconnect driveshaft, pull axle shafts so you can disconnect and hang the brake backing plate assemblies on the frame with some stout wire which makes it so you can reuse existing brakes, plus there is no need to open any brake lines, and the axle assembly is much lighter. Unbolt control arms at the axle only.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
