We don’t do it like that we take them off and install after engine is in car they will come right in from the bottom. With yours never being off the bolts might be a issue. If possible I would remove starter also. On a car like mine that’s been apart before the manifolds will take a half hour to do very easy. Also once your putting it together drop in engine then install starter wire it then the manifold works great.
