WB thanks for that table and info on how you are running with a similar setup. Really good info. And yes Tom, that "assume" seems to have once again got the better of me. Appreciate all your guys advice and help. Hopefully it will be useful to other along the way too. But seems like I am not in as bad spot as I thought.
With that said, Dick, I will circle back as I want to build a back up carb that is closer to my original aspiration of larger venturi. I'll drop you a line...
thanks again all.
